| Register | Gallery | FAQ | Members List | Social Groups | Calendar | Forum Home | Search | Today's Posts | Mark Forums Read |
| 4/3rds Cameras Includes Micro 4/3rds Cameras |
| Site Sponsors |
LinkBack | Thread Tools | Display Modes |
#1 |
MF Zoom with the Pen
I've just got the m43 adaptor for a few Hexanon lenses, to use on the EP-1. If there is a way to zoom when manually focussing, I can't find it.
Is there a way? BTW, the focussing on these Hexanons seems quite stiff -- some probably haven't been used for years. Is this normal, or am I just pampered by focus-by-wire?
__________________
Sláinte Bertie. |
#2 |
Re: MF Zoom with the Pen
If they are zoom lenses, you rotate the zoom ring or push it forward/back depending on wheter it is a 2 ring zoom or 1 ring zoom.
I suspect your Hexanon lenses are not zoom lenses if you cannot see an obvious way of zooming them. My father had an early Konica AutoReflex T camera and this was the first SLR I spend any amount of undue stiffness or slack in the focus ring but such problems do occur from time to time. If all are similar, then I suspect that it is that you are not use to using a focus ring with a mechanical link to the glass. Some focus by wire rings are too lose for my liking. |
#3 |
Perhaps the OP means magnified view, for focusing. In which case you just press the focus button (left hand button) then MENU.
#4 |
Robert,
Of course. Menu - * menu (default is turned off for this option) - *D - INFO setting - LV info - Zoom On. under LV info there are a number of screens...I use Zoom and crosshair grid only to jump from zoom to crosshair in two moves as there is a normal screen between. So with this setting you find focus hit the info button and a small green box appears. OK in center of ring selector to zoom OK again to drop zoom...you can go from 7x to 10x with the silver scroll wheel at to right on back. Info again returns to crosshair to align shot....info twice returns to zoom box. Repeat as needed....you can shoot from zoom screen and keep zooming in and out without the crosshairs if they are not needed. I set the Fn button to LCD on/off ... off when I am between shots. Makes sense after you have used it a bit. ![]() Bob |
#5 |
Thanks all; sorry for the confusion, I meant zoom as in magnify the image for better focussing -- the lenses are all primes.
Just tried it -- it works! PS - the Hexanon focus is quite a bit stiffer than on my Canon EF lenses, which was why I was a bit puzzled. Thanks again.
__________________
Sláinte Bertie. Last edited by Robert Campbell; 21st November 2009 at 15:51. Reason: added PS |
#6 | |
Quote:
Still haven't figured out how to turn the screen off more permanently. As soon as the camera goes to sleep and comes back the screen is on again. A bit annoying. I guess I could turn off the sleep mode, but that would drain the batteries faster I guess. Anyone have a suggestion. I prefer to use an external viewfinder. The Voigtlander 28/35 mini finder is a nice match for the Pen size wise. The 35mm frame lines also match the 20mm lens perfectly. This lens seems to be closer to a 38mm equivalent. Covers about the same as a 28 on the M8. -Thomas |
#7 |
Thomas,
Menu - * menu (default is turned off for this option) - *B - BUTTON/DIAL - Fn Function -Backlit LCD - OFF I set the Fn button to LCD on/off ... off until pushed again so even while shooting the LCD remains off. ![]() Bob |
#8 | |
Quote:
-Thomas |
#9 |
Thomas,
I see no setting to keep screen off...why not turn off sleep? With the screen off you are not using much power. D* menu again - Sleep (On times/ Off). So when you turn on camera Fn to off screen and you are done until you shut down and power up again. Bob |
#10 | |
Quote:
Perhaps something is amiss with yours? Regards......Richard |
#11 |
I suspect that they need a bit of TLC and CLA -- two came from my late father-in-law, and haven't been used for maybe 10 years; the other was a freebie when I bought something else in a shop...they don't owe me a lot.
__________________
Sláinte Bertie. |
| Thread Tools | |
| Display Modes | |
