The GetDPI Photography Forums
Go Back   The GetDPI Photography Forums > Digital Camera Forum > 4/3rds Cameras
4/3rds Cameras Includes Micro 4/3rds Cameras
Reply
Old 2nd May 2009   #1
UAx66
Posts: n/a
Kern Macro Switar 75mm f/1.9
Does this lens need machining for the G1? I know the non-macro is fine but there is no information about the compatibility of the macro 1.9/75 and the available c-m4/3 adapters.
Old 2nd May 2009   #2
butterdada
Posts: n/a
Re: Kern Macro Switar 75mm f/1.9
Kern Switar 75mm F1.9 is ok. Wide open
Old 3rd May 2009   #3
milapse
Posts: n/a
Quote:
I don't think so... I'll have one in hand soon so I'll add that info to the list.
Old 7th May 2009   #4
apicius9's Avatar
Quote:
Please let us know when you get it. I was weak, just picked one up at ebay, just when I had decided I was done buying... But mine will take a while to get here.
Stefan
apicius9 is offline   Reply With Quote
Old 24th July 2009   #5
honpan
Posts: n/a
Very impressive. I wonder if this lens would cover full-frame. I intend to modify it and use it on Leica M.
Old 24th July 2009   #6
petermcwerner's Avatar
I remember reading somewhere that it needs machining.
__________________
Peter Werner
Leica M8, R9+DMR & Digilux 2; Nikon D700; Panasonic FX01, FX150 & G1; Samsung TL350 (WB 2000)
petermcwerner is offline   Reply With Quote
Old 24th July 2009   #7
Hi everyone,
No machining necessary. In fact I have used and still using all Kern Switar lenses from 18mm to 180mm and non of them needed any machining. (not all lenses entirely cover sensor, but that no big deal for me) 26, 50 and 75 are my favorite. I also tried most Yvars and pizars and they worked great too with good image quality.
attached a pix with 75mm f1.9 on G1 with Hawks old adapter. (new works too and RJ adapter is fine as well)
Kern Macro Switar 75mm f/1.9-p3159040.jpg
Photomorgana is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Copyright 2014, GetDPI.comAd Management plugin by RedTyger
