The GetDPI Photography Forums
Go Back   The GetDPI Photography Forums > Digital Image Processing Forum > Image Processing
Image Processing RAW conversion, Image Editing and Cataloging
Reply
Old 7th August 2012   #1
LCC for 35mm full frame sensors
are there any LCC programs/options for ultra wide angle lenses on full frame 35mm sensors?
felix5616 is offline   Reply With Quote
Old 7th August 2012   #2
MGrayson's Avatar
Re: LCC for 35mm full frame sensors
I have made LCCs in Capture One for the Leica M9. I don't see why you couldn't do it for any camera, although I don't know if it requires RAW. (I'd like to see an LCC for a phone camera... )
--Matt
MGrayson is offline   Reply With Quote
Old 8th August 2012   #3
Images: 7
Yes. You can use LCC on nearly any raw file. A few exceptions include the 5D II sRaw raw format (the lower resolution "raw" file).
Benefits:
- high speed good quality automatic sensor dust removal based on the LCC
- light fall off correction
- color shift correction
On dSLRs the color shift is very minor, but on a 17TS with movements on a Canon 7D you can see it is there and often you don't notice it fully until it's corrected and you can show a before/after.
On the M9 there is considerable color shift despite the built-in corrections the M9 is doing behind the scenes. This "residual" color cast is handled very well.
A word about light fall-off: many people love a specific lens BECAUSE of it's fall off or lens-vignette. The thing is the vignette is only at it's most beautiful when the frame is uncropped. When you present several images together if one of them is cropped and the others are not then the vignette will not be uniform. For some aesthetics/purposes/subject-matter/intentions this is not ideal. By using LCC you can first correct the frame to be completely even, then crop the images as you please, and then reapply a vignette to the final crops. All of this can be done in raw, and, if it's the same lens/aperture then it can be done to all images at the same time using a style so that the total time to do this is mere seconds.
This is what I do with nearly all my reception dancing photos at weddings when using my 24-70L@24mm@f/2.8 on a 5D Mark Whatever. It creates a uniform beautiful vignette, allows me to crop freely (including verticals from horizontals), and takes literally seconds: sort by focal length, select all 24mm, apply "24-70@24@2.8 LCC" style (which I created one time last year), sort by date, continue editing.
Since (after the initial proxy build) C1 makes these adjustments based on the proxy (unlike LR or Aperture) these files are immediately available for continued editing (I don't have to wait for the files to "snap" into an adjusted state - they are already 100% redrawn a few seconds after applying the style).
__________________
Doug Peterson (email )
Digital Transitions: Phase One, Mamiya Leaf, Arca-Swiss, Cambo, Profoto
Office: 877.367.8537 | Cell: 740.707.2183
Capture One Training
dougpeterson is offline   Reply With Quote
Old 10th August 2012   #4
Any tutorials online how to make an LCC?
Thank you,
Valentin
Valentin is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
