The slow lenses
V
Vivek
Hektor, Summar and Elmar- specifically. They are old and slow.
Do you use them and like what they offer?
HeavyDuty
I have a 90 Elmar-C that I picked up years ago when I got back into RF photography simply because it was on budget, but I've learned to love how it renders. I'm actually a big fan of moderate aperture lenses! Fewer optical compromises seems to be a common feature.
I have a 1936 uncoated Summar. Old it is, indeed, but slow? After all, it´s f/2, and to get the special character of it, it should be shot wide open. Then, it gives a rather strong, ´veiled´ flavour, at least if the lighting itself is interesting, and the bokeh is OK.
Once it´s stopped down, however, that character gives place to a contrastless greyishness, somewhat like an dusty old lens without a lens shade. And the bokeh gets horrible, probably due to the rather unusual shape of the diaphragm leaves.
V
Vivek
Per, Thanks for the correction. Even the Hektors can be quite fast (125mm f/2.5). I had the 2.8cm f/6.3 Hektor in LTM, in mind, as an example.
philipus
I have a Hektor 13.5/4.5 LTM from 1938, which I use on my M6TTL. I shot most of my surfing photos with it (shameless plug) philipus.com » Surfers
The long focus throw is both a blessing and a curse. Insanely precise but rather slow for action shots.
I also have a 9cm/4 Elmar from 1934 which is lovely too. Feels so solid and nice. Looks brand new, incl the glass. I don't use it as much as I should though because I love the 90 Elmarit-M much more. The Elmar gives a different look though.
Edit: I forgot to add I have a 1950 Hektor 2.8cm/6.3 which is nice too. Flares a bit shot into the sun, but renders nicely. And is ridiculously small of course. The below is without sharpening or other edits, except colour correction in ColorPerfect (Portra 400).
cheers
philip
V
Vivek
Thanks for the fine example, Philip!:)
That 2.8cm Hektor is really tiny, yes.:)
dude163
i have a 1958 elmar 90/4 and its neat, i have to enhance the contrast a bit if i take colour, but it does great B+W
