The GetDPI Photography Forums
Go Back   The GetDPI Photography Forums > Other Discussions > Lighting Forum
Lighting Forum Gear and Technique
Like Tree1Likes
  • 1 Post By fotografz
Reply
Old 24th February 2012   #1
johnnygoesdigital's Avatar
H1 with metz 54 MZ 4I
I'm curious if anyone has experience with this flash and an SCA 3209 adapter. I'd like to use it off the viewfinder of an H1 for more than just fill. Thanks.
johnnygoesdigital is offline   Reply With Quote
Old 25th February 2012   #2
Images: 87
Re: H1 with metz 54 MZ 4I
Quote:
I use a Metz 54 ZM-3 speed-light on an H camera ... same flash I've shot with a H2 ... then H3 ... and now a H4. Also a Metz 75 Potato Masher. I tried to use the Metz TTL transmitter module in the hot-shoe to fire those flashes off-camera and never could get it to work. I think it's a line of site inferred system anyway ... which is all but useless.
IMO, your best bet is to use a radio transmitter on the camera and a receiver hooked up to the Metz 54. ... then you can put it on a stand, or hold in your hand for some directional control. Or if you just want to get it off the prism and hand direct it, any off-camera cord should work to trigger it.
The way I work with the H now is use the Metz in the hot-shoe set to TTL for fill, and use a radio transmitter hooked to the sync port in the H to trigger any number of strobes or speed-lights ... The old SunPak 120 J bare-bulb works great for this off-camera application.
Hope this helps a little.
-Marc
ghoonk likes this.
fotografz is online now   Reply With Quote
Old 27th February 2012   #3
Thanks Marc,
Those are great ideas. I like the portability of using the Metz W/TTL, as a fill and perhaps getting more juice from it. It's easy to hold the H too, so using the wireless is a great option, i'll try it. Thanks again.
john
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
