Leica M8 IR-Compatibility Lens listing: IR hotspot or not
JimCollum
No Hotspot
Leica 21mm 2.8 Pre asph
Leica 21mm Asph
Zeiss 28mm 2.8 Biogon
Leica 50mm 1.4 Summilux preasph
Leica 50mm Summarit
Leica 75mm 1.4 Summilux
Leica 90mm Summarit
Leica 90mm f2.8 Tele-Elmarit "Thin" version
Leica Tri-Elmar 28/35/50
Hotspot
CV 15mm Heliar
Zeiss 18mm
Zeiss 21mm 2.8 Biogon
Leica 24mm Asph
Leica 28mm Cron
Leica 35mm 1.4 asph
Zeiss 50mm 1.5 Sonnar
Leica 90mm 2.0 APO
WATE
MikeScecina
Re: Leica M8 & Lens listing: IR hotspot or not
Oops...too bad Jack. I'll give you $475 for that 90.:ROTFL:
Sr. Administrator
Staff member
Sheesh Mike, I can do better on eBay LOLOLOLOLOL!
Bob
Administrator
Staff member
How about
35 chron asph?
WATE?
-bob
JimCollum
haven't tried that one.
i plan on testing as many as possible during the Moab workshop.. given the amount of glass that will be there, we should have pretty much everything covered
jim
C
Chris Herbert
I'll have those two with me, too, Bob! I suspect the WATE is okay, as LFI did a spread where it was used for IR (false color) and the shots looked beautiful.
Chris
Bob
Administrator
Staff member
What is a quick test for hotspot or not?
Wide open or fully stopped down?
thanks
-bob
Bob
Administrator
Staff member
p.s.
I have it on good authority that Moab is NOT a hotspot:ROTFL:
JimCollum
the more the lens is stopped down, the more visible the hotspot. as an example, the CV15 exhibits a hotspot, but you can use it fairly wide open with great depth of field, so it might not be apparent in a print
jim
Bob
Administrator
Staff member
Maggie,
an IR Hotspot will look like a hazy light blob in the middle of the image.
It shows up more at small apertures with an IR-pass filter mounted on the lens (such as a B+W 092 or 093).
If you look at the image in PS in the channels view, it is most visible in the blue channel, so one strategy to make it go away is to use only the red channel. Unfortunately, that limits you to a monochrome rendering unless you overlay with color from a non-ir filtered image.
-bob
Maggie O
Have you been shooting IR pictures with an IR transmitting filter in front of the lens?
Ah, so it only manifests when shooting IR with a filter?
That would explain why I haven't seen it.
Obviously, I am a complete idiot and possibly illiterate.
Sr. Administrator
Staff member
the B+W 092 and the Hoya 72 are the same and will cover most of the lens sizes you are likely to need...
