The GetDPI Photography Forums
Go Back   The GetDPI Photography Forums > Digital Camera Forum > Sony
Reply
Old 18th January 2012   #1
Images: 59
NEX-7 and TTL flash
The small Sony HVL20-F20AM does a fabulous job for indoor portraits with fast lenses. The same flash also works fine as a wireless commander.
Both very, very good!
It took a while for me to find the flash compensation settings- hidden in Brightness and Color section.
It appears that there are no possibilities to assign a custom key function for flash compensation. Only the flash modes can be assigned to a soft key.
I wonder if a firmware update can address that?
I would also very much like to see a more versatile but compact flash from Sony for the NEX-7.
Vivek is offline   Reply With Quote
Old 18th January 2012   #2
Images: 59
Re: NEX-7 and TTL flash
The degree with which the tiny HVL-20 can be controlled even for close-ups is quite impressive. Here is an example.
Untitled by Vivek Iyer, on Flickr
NEX-7, Olympus pen F Macro 38/3.5, HVL-20, 1/160s, f/3.5
The cork was entirely entirely by the flash light.
Old 18th January 2012   #3
jonoslack's Avatar
Images: 1
Excellent Vivek . .. did you open the bottle specially?
__________________
jonoslack is offline   Reply With Quote
Old 18th January 2012   #4
Images: 59
Thanks, Jono.
No, remnants from the New years. Although, it did call for a new one.
I knew the Maxxum flash system was superb. I did not know that Sony continues in that tradition and even with manual focus lenses (Nikon's iTTL only works with their CPU enabled lenses)!
Old 18th January 2012   #5
Vivek, you CAN assign flash compensation to a key. I have Custom Key Settings | Right Key Setting | Flash Comp set. This is the click on the right side of the rear dial.
Also, I have flash mode assigned to the lower left button. I have the AF/MF selector switch set to magnify for MF.
Hope this helps!button to
shelt59 is offline   Reply With Quote
Old 18th January 2012   #6
peterv's Avatar
Quote:
Hi Vivek,
no, you can assign a custom key function for flash compensation:
From the Set Up Menu choose:
Custom Key Settings
Right Key Setting
Flash Comp
Very handy, I use it all the time with flash.
peterv is offline   Reply With Quote
Old 18th January 2012   #7
jonoslack's Avatar
Images: 1
Quote:
Originally Posted by peterv View Post
Hi Vivek,
Custom Key Settings
Right Key Setting
Flash Comp
Thank You Peter
now all you have to do is to tell me how to set the shutter speed max and min for auto ISO and I'll be in heaven1
__________________
Old 18th January 2012   #8
peterv's Avatar
You're welcome, sorry to tell you I can't give a positive answer to the auto ISO. Looked it up in the manual again, but it's just not there.
Would auto ISO in combination with Program shift be helpful? It's actually quite fast with the Tri Navi...
Old 19th January 2012   #9
Images: 59
Peter, Thanks a bunch! Very useful!
I now have quite a few combinations to play with and settle down to.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
