I wonder what kind of result my Sony A1 would produce if it had "Pre-Capture".
So I was shooting my A9.3 with a frame rate of 30 FPS and Pre-Capture ON.
The GIF displays a linear resolution of 1200 pixels on the long side.
So the resolution difference between the A1 and A9.3 won't matter as the images are only slightly cropped.
At 30 FPS the GIF should repeat in about 1 s to give the correct speed impression of the actual event captured.
Setting a delay of 0.03 in Photoshop after each frame seems to accomplish that.
Here goes.
Sony ILCE-9M3 + FE 400mm F2.8 GM OSS + 1.4X TC @ 560 mm, f/4, 1/3200 s, ISO 1250.
To me that seems like it would be a very useful addition to the A1 feature set.
What is your take on this?
If the A1 had this feature I am not sure that I would have bought the A9.3.
But now that I have gained some experience at 120 FPS on the A9.3, getting the A9.3 was the right way to go.
A frame rate of 120 vs 30 FPS is really a different ball game, not even close.
A buffer of 192 images allows for these shooting durations before the A9.3 slows down to 6 FPS:
• 120 FPS - 1.6 s
• 60 FPS - 3.2 s
• 30 FPS - 6.4 s
• 15 FPS - 12.8 s
unless the buffer can also being emptied while written to.
