rdeloe
I don't think this is a Pico issue but more a camera to lens FFD needed issue. I don't believe the Schneider 35XL ( if that is the lens you are referring to ) could ever be used with a mirrorless camera unless the sensor was almost flush with the camera opening.
Please correct me if you are referring to a different lens....
Victor B.
Nope. Same lens.
It's another "perfect is the enemy of good" situation. It's one of my most used lenses on my F-Universalis plus GFX outfit. Officially, it's indicated as can't be used because the rear lens cell goes inside the GFX camera mount, which limits movement to 7.5mm. Some people take the view that if they can't use the whole image circle, then they won't use it at all. I take the view that I need an excellent 35mm lens and I will live with 7.5mm of shift!
Fun fact: I could have the entire image circle were I brave enough to try again to machine down the rear housing for the cell, or to build a new housing. There's no no reason the housing has to be that thick; it was just the cheap-and-easy solution, and it made perfect sense with mirrorless backs. S-K did not anticipate anyone would do what I'm doing. However, if they had gone with a slim and trim solution, mirrorless camera users would be in business.
