Thank you guys for your valuable advice.
I have a lot of reading and learning to do before I decide on anything. But the photos you post show that this could be a good direction for my photographic adventure.
This 60 xl lens from the descriptions is the first one I found that met the criteria. But if there are any other sharp lenses with a range that will not limit me, I will gladly consider them.
Thank you very much Rdeloe for the description and explaining the focal length issue.
As for the Hasselblad V, I do not want to go with the Hasselblad V or X for several reasons. I currently have a similar sensor. I do not need IBIS. Live preview, it will make things easier, but my target equipment is the H6D-100c. A larger sensor, 16Bit and a larger tonal range, LV probably works correctly since it has video options.
TimoK could you post some examples of photos you took with your set?
The landscape does not run away and currently it takes me a lot of time to take photos. I think I will actually start with something 52-76 mm and ask a dealer for a demo. I would also like to ask about setting the focus closer than infinity.
Do I understand correctly that thanks to the Bellows, each lens will behave like a macro and the tilt will make it easier to increase the depth of field? Here is an example of a 4-photo panorama, but I did not have a perfectly set nodal point and you can see the cuts.
