I wonder if the beauty of the fat pixels you see can be attributed to the drawing of the older lenses instead. I see an "improvement" when shooting with older V instead of new XCD lenses.
Welp, these latest posts got me thinking (dangerous, I know)... Having convinced myself that the legacy V system lenses render less clinically than the modern lenses (that old "Zeiss magic" thing), I decided to put my assumptions to the test, holding as many parameters constant as possible. So...Very interesting. Sometimes tricky to correctly ascribe causation when two variables change simultaneously.
Cue run-up in prices on older V lenses…
Lenses tested: XCD 3.2/90 vs Zeiss CF 3.5/100 Planar
Subjects: two of my old V system lenses, shot at an approximate distance of 1 meter (adjusted to give comparable fields of view), focused on "f=120mm" of the front of the S-Planar
Camera/sensor: Hasselblad 907x-CFV100C
Camera settings: aperture priority automatic exposure; same white balance settings for all; electronic shutter
Post processing: Phocus using default settings (w/default lens corrections for XCD90 including CA corrections; no lens corrections applied to 100 Planar); cropped square and exported as jpegs without any additional adjustments
Each lens was tested at f/3.4~3.5, f/4, f/5.6, f/8, f11, and f/16. Below are sample images shot at f/3.4~3.5 and f/8. The entire series can be found here.
I'll leave it to folks here to draw their own conclusions, but with the exception of focus roll-off (seems steeper with the XCD90), to my eyes the old and new glass render more similarly than I had expected, at least under these conditions. It's very possible that more obvious differences might be found with different lenses (the 3.5/100 Planar is touted to be one of the sharpest lenses in the lineup), but I'll leave it to others to go down that rabbit hole. Suffice it to say that the old V system lenses more than hold their own - I'm happy to keep them in my kit alongside the XCD lenses.
John
