Dears,
My name is Marco Ristuccia, I'm a computer engineer based in Berlin.
I'm also a photographer, and I happen to own a beautiful 907x + CFV-100c.
This is a message that should be firstly addressed to the
Hasselblad/Phocus Technical Team, and in
second instance to the
Hasselblad Commercial Team.
Since I frequent various photography forums, including the GetDPI and DPReiview medium format ones,
I know that you're well aware of a serious technical issue which makes the use of the CFV-100c as digital
back on technical cameras a challenge, and which gives the Phase One backs
a huge advantage in respect
to your product.
I'm talking about the PDAF banding issue, which affects images taken with the CFV-100c on a technical camera
when using wide angle technical lenses, mostly Schneider-Kreuznach rectilinear (symmetrical) lenses, still widely
used, but also some of the common Rodenstock ones.
This is proven by the many who tried personally the various combinations.
Your technical team has already answered to the ones who complained about this, but the answer is vague and
does not seem to give concrete hopes on the possibility to have a fix, either in firmware or in Phocus.
A member of the GetDPI community already shared with you a workaround, which you recommend as a fix
when asked about this issue.
Now, I myself have spent a big time working on potential solutions.
At first, I've shared (still on GetDPI) a simpler solution, which makes use of an inverted and normalized flat-field
image (LCC / Scene Calibration) put in overlay over the real image in Photoshop. This works pretty much well, and
is less noise-prone than the one you're currently recommending, but it is still tricky to fine-tune as the first one is.
Then, I worked on a real tool, which I've just finished to develop, which simply
applies the flat-field (scene-calibration)
without blurring the LCC first. If applied properly, like it is documented by the ample literature on the subject, it
works great and it has the advantage of not only removing PDAF banding, but also dust spots, sensor tiling, etc...
I know that not pre-blurring the scene-calibration image may induce some slight noise in the final image, so you could
just provide it as an option that can be turned on or off depending on the situation, and/or apply a slight noise reduction
after the fact.
Now, I'm going to offer my tool to the community, and there are already other softwares that do it right as well,
like RawTherapee to name one. But I sincerely hope that you could implement such enhancement to the Phocus'
Scene Calibration algorithm. The technical cameras' community, of which I myself am a part, could then benefit in
full from your fantastic digital back and, maybe, you'll gain some market share among the technical camera users
like the high-end landscape photographers and architects over Phase One due to the better cost/quality ratio.
So, I've shared some concrete solutions with you, and I've a tool which I'm going to sell until you'll come up with a
real fix. My tool is also able to perform frame-averaging and frame-median on 3FR RAW images, keeping the final
combined image still in the original RAW format. This is another feature you should consider to implement, and
which is already offered "in-camera" by Phase One for example.
Now, this should not be my business, I'm putting a small price tag to my tool only to recover some of the time I've
spent on such topic. But it really should be your business, and I sincerely hope that sooner or later my tool will not
be necessary anymore. You have way more resources and better technical know-how than what I alone could ever have.
I hope this email of mine will raise your awareness of the issue further.
Right now your tri-fecta is more of a 2.5-fecta.
Feel free to reach me out in case you need further details on how I've fixed the issue.
Marco Ristuccia
Photographer & Computer Engineer
