Paul Spinnler
Hi guys
I figured it's nice to heap some praise on some legendary vintage lenses and discuss them a bit more in detail – because why not? It is getdpi.com, after all.
I've been reviewing some of my 60 XL files and must say that this lens stands above the rest in so many ways. Just astonishing.
So – it is a late-gen SK lens, ie part of the last "Magic Four" (let us pls. call them like that, they are great) created by Schneider before they closed shop and timeline-wise just at the same time as the release of the Rodenstock HR lens series.
The Magic Four are: 28 XL, 43 XL, 60 XL and 120 ASPH. IMHO if you'd want to slot in equivalent magic Rodie lenses it would be the 32, 90, 138.
The 60 XL is the most versatile in the set in that respect it is very dear to my heart. It is a lens you can build a system around, or, for lack of an alternative, live with when just starting out.
The 60 XL is a double gaussian design with extreme sharpness and linearity:
Here a snip on the edge 30mm shifted on my Pano:
Centre:
ARE YOU KIDDING ME.
EVERY LITTLE BRANCH OF A TREE ON A HILL MILES AWAY ACROS 30MM SHIFT LEFT AND RIGHT. CAN YOU SAY 320 MEGAPIXEL STITCHES.
This lens weighs almost nothing, has endless, truly endless shifts, and is fully rectilinear.
The 60mm focal length is totally flexible. Portraits, architecture, and landscapes with stitching.
Highly recommend! There's nothing comparable in MFD land, IMHO. Even with an IQ5 with 250 megapixels this lens will deliver resolution. And then shift like that.
I am surprised that SK closed shop with the quality they pumped out in their last series.
Comparing it with Rodie glass it also acts differnetly; up until F11 it is less sharp, I feel, with a wonderful analogue "underlying sharpness"; ie all details are there, but a tiny bit softer. Rodie glass in comparison is like the shot above at F4-5.6 already. BUT this is not a disadvantage; in that sense the 60 XL has a beatiful look and it is also more contrasty I feel compared to the Rodie lenses.
I think if there's anything like an "investment concept in MFD" then the SK Magic Four come as close to that as possible. Rodie HR lenses are also great, but given they've been in production for so much longer - more than a decade longer and still available – it essentially means that you'll most likely always have the best Rodie glass at a slight discount to new – because they are still great and rare –, while the Magic Four will keep or increase value IMHO.
There's just not so many to go around and even if the pros move onto Fuji there's just still such a high utility value in them that it is difficult to imagine pricing moving. It is a bit like luxury real estate in a down market - demand outsripps supply so dramatically, you'll always have one guy wanting the 120mm IC super sharp, compact lens ...
Hassy will release a new back and for all we know IQ5 is just a question of a new sensor given the main business is alive and kicking.
Bright future therefore for this little gem of a lens, a true desert island essential.
The MFD lens equivalent of a diamond. The rarity is commensurate with this definition: while there are thousands of Rodie lenses of each focal length in the market, there are low hundreds across all manufacturers of these available globally.
I am not familiar with the 60 XL sales numbers, but the 28 XL Helvetar has been limited to 50 units in Alpa mount, globally. 50 on a planet of what 8 billion?
The 60XL may have been produced a few hundred times, but the lesson is this - don’t let these ever slip through your fingers.
– Laudatio END
- Has a 120mm IC, which is unparalleled below 90mm and that lets you shoot 6x9 and digital with endless shift
- On my Pano I can shift to almost 30mm and still get crips detail, see shots below
- The microcontrast is best in class; it is the sharpest SK lens I own and up there with the Rodie HR crispness
- It has slight vignetting and requires LCC with an IQ4 as soon as you do extreme shififts, but on a small scale it is very well manageable
- It is fully rectilinear, meaning it is the ulimate one-trick architecture lens – combine it with an Rm3DI or Alpa Max (arch cams of choice) and you have all you need to create 300 megapixel monstres of pictures
- On an achromatic back it is a dream
- There's a CF, but it works very well without with the IQ4 gen of sensors
Centre:
ARE YOU KIDDING ME.
– Laudatio END
