Larger sensor, frame averaging built-in (focusing on advantages only).So what is the advantage of Phaseone?
Was going to say the same thing. The results from a single IQ4-150 exposure “should” be equally good. As impressive as Dualexposure mode is, it is largely unnecessary most of the time due to how good shadow recovery already is in C1 with sensors from that family.I would be interested to see a single exposure from the IQ4 150. In my limited experience with the IQ4 150, I find that the benefits of Dual Exposure+ aren’t readily apparent until one pushes the files much harder, on the order of shadows @ 100 and exposure +3 or more. I agree that the combination of hardware and software really is amazing.
The gap between these different formats is becoming narrower in terms of image quality, noise, etc. However with its larger sensor the IQ4 150 offers greater capabilities and flexibility when using a tech cam. YMMV, of course.
John
IMO, the main feature of frame-averaging is increasing the DR and reducing the noise, not the ND filter simulation. I can shoot a heavily underexposed image with my m43 camera (in-camera frame averaging) and have the same noise in the shadows as GFX100.I find that I can easily replicate frame averaging with stoppers. Sure, it isn't as convenient as having this built into the camera but for sure it can be replicated. I was mostly concerned about replicating the dual exposure feature and other than really picking apart an image I believe I have.
Victor B.
Hello Paul,Frame Averaging, is great as long as you have no subject movement, for landscape work, it's basically a non starter, as the movement of leaves, grasses, limbs etc create a total mess. Images are clean as previous mentioned, and until Dual Exposure came out I often bracketing a Frame averaging shot with normal work, knowing the noise would be much less. Dual exposure IMO creates the same clean, possibly cleaner file and so far in my work has not created the same aliasing movement issues that are created with Frame Averaging.
Frame Averaging can play interesting effects on moving water, sometimes good, others not so good as it's very easy to get the same movement aliasing issues at times.
Great tool however and as previously mentioned same effect can be done manually in CC but takes more time and it's nice to have the file already worked up ready to use.
Paul
The point of frame averaging is to act like an ND-filter, i.e., the movement gets blurred. The blurred parts should look the same as if applying a long exposure. Is that not the case with Phase One?Hello Vieri:
I tired it pretty much through out the range of exposures. If there are any trees moving, or limbs of trees, etc. you get a totally blurred image as there is not way the tool can align this type of motion. Even a slight wind can effect the shot. I quickly tried FA, outdoors, and realized it would have limited use in most of my scenes unless I was lucky enough to be in the Grand Canyon or similar all rock setup. It's been a while since I fired off FA, but usually I believe I was averaging around 25 frames or less. The only issue I had was the wind motion and excessive blur, but you can see the same effect with cars, people (depends on shutter speeds here) etc. You can frame average at 1/250 even 1/500 but if there is wind you still get the issues. At least I do.
With Dual Exposure, I have used it with mild to moderate wind and still rarely see any issues, sometime slight movement in pine needles but overall it accommodates motion very well.
Frame Averaging can at times have aliasing with water, it's very scene dependent. There are times I love the effect it gives to a slow moving body of water, but a fast moving stream where I want to.create classic slow exposure blur, can create artifacts.
For interiors or architecture without trees (again due to movements) FA is a great asset as you get IMO overall sharper images and definitely considerably less noise.
But for my work Dual Exposure is the real game changer.
Paul
