Print, black and white, proof view
spassig
Hello
I use CaptureOne and the Epson SC P800 printer.
For color prints, I can select the respective ICC profile for printer/ paper in the proof view to roughly simulate the printout.
I do not do this with black and white printing, because I then set color management via manage printer and set it black and white in the printer driver.
Is this procedure correct and sensible?
That doesn't give me a proof view?
Thanks for feedback
Jochen
MartinN
Well, the Epson BW mode vs Normal Color Mode is a bit like comparing apples and oranges. With a good printer profile you should get good BW prints in normal color mode, but you lose the tweaking ability in Epson BW mode. However, you gain ability to proof the result and tweaking can be done before printer driver, in Lightroom or Photoshop. I try to avoid finicky magic things like Epson BW mode, but that is me.
spassig
@MartinN
Hello
I translate your answer and hope I understand it.
I used the color mode in the past.
I and other see a minimal color cast in the black and white printout.
Jochen
MartinN
A color cast could probably be minimized by a custom built printer profile for your printer and paper.
MartinN
Yes, many paper manufacturers provide profiles, but a really custom built and measured profile may be even better.
pflower
I find Epson's ABW mode superior to using a colour managed process with icc profiles. But each to his or her own. You can't soft proof B&W files in LR but you can in Epson Print Layout - free and available for download. So if you want to soft proof B&W files you might like to have a look at EPL.
spassig
@Blume
Thanks for feedback.
I have install EPL. I doesn't know it yet.
Workflow?
First I must export a BW picture from CaptueOne or Photoshop or Lightroom?
(I prefer CO)
Then I can open the BW with EPL?
Jochen
bensonga
The answer to your final question is: Your first step in Epson Print Layout (EPL) will be to select File/Open and then open the file that you want to print (from wherever the file resides on your hard drives). EPL is as close as we can get for soft proofing images to print with Epson's ABW driver. I use it all the time now for making BW prints with my Epson P800 and ABW.
By the way, the Epson ABW driver functionality does NOT use ICC profiles. ICC profiles are only used for making "color" prints with Epson printers (including making BW prints in the "Color" mode vs ABW mode).
