I am considering the SL2, and have a couple of questions I hope that current users can answer.
1. With manual focus, and Live View, with most other cameras I have used you can double tap the rear screen to zoom to 100% view and then move around the screen. From reading the manual on the SL2, it seems that works similar to the Q2, i.e. you zoom in by moving the focusing ring on the lens. I like this on the Q2, however still would like to have a double tap or similar feature available. The Q2 is a dedicated lens, the SL2 takes any L mount or older Leica lenses with adapters. If you are using a Panasonic L mount lens, I assume this works the same way, moving the manual focus ring zooms into Live View. But how does a non Leica lens work, say a Milvus 15mm for Nikon F mount. With an adapter this lens should work perfectly on the SL2, in manual mode. But not sure how I would zoom into 100% view on live view.
2. The non tilting LCD for me an issue as I do like to shoot low to the ground and at times having a screen that is moveable in position is a huge asset (please Phase One, get Capture Pilot working again for the IQ4). Can you use the Leica photos app on iPhone via bluetooth to view the Live View screen to help setup the shot? I know you can fire the camera from the app, but curious to know how others find the app for viewing a scene.
Thanks in advance, Leica is increasing the price 600.00 on the SL1 04/01/21, so I want to move forward before then.
The Panasonic S1R, I realize is another solution, however the more simple design and layout of the SL2 appeals to me, and less mass and weight.
Paul C
Paul C
