Warning: Long post!
This has been an enlightening few days. Every time I do a test like this I gain more respect for people who do robust tests. It’s very hard to do, and I don’t think this one is all that robust. There are so many factors that come into play even when doing something as simple as trying to compare a shot with vs without a center filter (CF). Same back, same camera, same lens, same f-stop; still a myriad of problems…
The biggest problem is the center filter changes the exposure (obviously). The only way to account for that in this test is to use the shutter speed since the test is very dependent on f-stop. Shutter speed is in 1-stop increments, which is too coarse. In order to get images to compare I had to reduce exposure on the shots with a CF by an average of -0.27 (1/4 stop).
The next problem is the LCC over-compensates for light falloff in my opinion. I don’t understand this since the LCC image is dead flat across the frame once correction is applied to itself. Yet when applying the LCC to an image it definitely gets brighter out at the edges. Compounding the problem is the fact that blue sky is not even across a wide 43mm frame, especially when shifted. This time of year the sun is still too low in the sky where I live to get an even distribution across the frame. All this is important because as the lens fails out at the edge it gets de-saturated and contrast goes flat with the LCC applied. It is not easy to judge between these failures when the image appears to be getting brighter at the same time. This overcompensation brings up the question: Should I do this test with “Light Falloff” at 100% to produce a technical comparison or should I mess with that slider, which of course adds my subjective eyes into the equation…? In the end I did one example both ways.
This could have to do with how I shoot an LCC. I simply slow the shutter speed 2-3 stops, hold the card with my thumb and middle finger in front of the lens with my hand below or to the side and shoot. I target a brightness of 200-230 after the LCC is applied. Is that too bright? Is my hand affecting the LCC? I should know this stuff!!
I did these tests with horizontal shift because with the IQ180 shifting the long direction has significantly more color problems. I will show the result of a vertical stitch shifted 18mm L/R.
Conclusions:
In these images, adding the CF makes a difference, but not as much as I hoped. A better test would be one where the image has some dark areas in the corners in order to compare noise in the 6-12mm shift range. I suspect that would show a bigger difference.
After about 10-11mm shift, the image gets pretty soft for my taste. So for me success is defined as getting a “well-corrected” image out to 11mm shift. In that regard, I am glad I got the CF. Not to mention the LCC will not work as hard on all un-shifted images.
All of this is image dependent. There are many images I have that look pretty darn good out farther than 11mm because the subject matter is forgiving. Even in architecture, a gray building could be shifted more than one with strong colors because of the saturation problems.
The problem here is clearly the IQ180’s ability to handle light at steep angles. A 18mm horizontal shift both ways is a 98mm image circle. The 43xl is supposed to have a 110mm IC, and I bet it does. This is not much of a light falloff problem; it is a colorcast problem. That’s why the CF does not make a huge difference.
The good news is it improved the image to the degree I needed. Horizontal shifts go to about 11mm, which I am happy with. Vertical shifts (movement in the short-side direction) seem to work very well. With a simple grad adjustment in LR (saved as a preset), I get workable stitches. So for me it is staying on the lens and was worth the $$.
Technical stuff:
SK 43xl Alpa mount
Schneider center filter IIie
Alpa STC
IQ180
Phase One LCC card
Processed in Capture One 6.3.5 using “Analyze (technical wideangle)”
Color readout applied to image center then Exposure adjusted to match
Exported to Lightroom 4 as 16bit tiffs with sharpening disabled
Apply sharpening in LR
Experimented with grad adjustment in LR
Please don’t judge these images on sharpness or artistic qualities. Frankly they suck for that.
Sand Pile
This was my first attempt. Unfortunately I moved the camera when taking off the CF, but the clouds moved anyway. You can clearly see what happens on the right side. Now before you scream too loud, that is the equivalent of a 98mm image circle. I think the CF extends the usable image area about 1/3 further than without the CF.
With CF
No CF
Here is a quick attempt to add a grad in LR to the CF image. There is a contrast & saturation boost, along with tint adjustment to reduce magenta cast.
Settling Pond
Another direct comparison with and without a CF. First with no LCC applied:
With CF
No CF
Here with LCC’s. Subtle, but the CF image has less cast. I adjusted the falloff on these images: with CF 67% falloff, without CF 81% falloff.
With CF
No CF
Here is the CF image with a LR grad added on the left side to compensate for contrast, saturation and magenta cast. Still needs a bit of work...
Ladue Reservoir
This is a three-image vertical stitch shifted 18mm. Turns the 43 into a 32mm. Nothing was done other than applying the LCC’s and stitching in Photoshop CS6b. This image is 150MP
With a little bit of work I think this is a usable combination. Before I only went to about 12mm.
Camera Porn
Here you go…
Ciao,
Dave
