Placing this here as I don't see that much traffic in the "software" forum for C1 issues.
Just wanted to give a heads up, as it appears the old way, (which worked for the last 15 or so years), no longer works for downloading C1.
You have to go to The complete photo editing software solution | Capture One and login. If you try the old way which is the way it worked for 15 years, by going to Phase One and logging it, you may get an error, which implies your trial has run out and you need to purchase a new license.
There has been nothing I can tell to show this process and how you are supposed to navigate the PhaseOne/CaptureOne process, that I am aware of.
So here is my exact scenario.
1. Wanted to upgrade from 20.0 to 20.0.4. I have a perpetual license installed on 20.0, thus I should be able to upgrade to any new version of C1 20.
2. Went to the Phase One site, and tried the NORMAL process of downloading C1 upgrades, by logging in, and was told "your trial has expired, you can either purchase or upgrade".
3. After about 20 to 30 minutes of going back and forth on the site, a pop up box appeared stating "We have a new site, www.captureone.com", and I headed there.
4. First 3 attempts brought up a bad URL, then finally The complete photo editing software solution | Capture One loaded.
5. Go through the same process of logging in, and you can get past the "your trial has expired" BS and actually download the update.
I FULLY understand what's going on in the world right now, saw it coming before many. However if you are going to change a process that has been in effect for 15 years, for a production piece of software, PLEASE, add something to your website, or send an email to allow users to understand what's going on. Support for any type of software is very limited right now, but changing a fundamental process of downloading just an update IMO is a mistake, without adding any explanation.
The entire process of licencing C1 IMO has gone south, started with version 20, which did not upgrade from 12 the same way, then trying to install C1 DB became somewhat of mess, (no longer can select DB from installation menu have to get a license code a process that was not straight forward either.
So many folks may have already updates to 20.0.4, but I am sure when the next update comes out, the process will be just like what occurred today, just wanted to give a heads up.
Paul C
Paul C
