Darn, I forgot about that. Yes, that's better. Thank you.Shogun still has it for $118:
I'm not sure I follow you there really. A 100% crop is a 100% crop, why would it be used in an inaccurate way?I should note, this is how large it is when viewed 1:1 on my 1920x1200 screen. The phrase "100% crop" is probably over used and inaccurate. The "actual" full size sample can be found here:
Hi,Can anyone with both the PL 45 2.8 and G 45 2 comment, compare bokeh and center sharpness?
Well, how is a 100% crop measured? Is it 10% of the whole image, 30%? Doesn't the whole idea of a 100% crop seem weird when everybody has a different size monitor? My 1:1 view is going to be different from somebody using a 720p monitor.I'm not sure I follow you there really. A 100% crop is a 100% crop, why would it be used in an inaccurate way?
/Jonas
The term "100%" crop is quite unambiguous -- and independent of monitor size or the size (in pixels) of the crop or of the original digital image.Well, how is a 100% crop measured? Is it 10% of the whole image, 30%? Doesn't the whole idea of a 100% crop seem weird when everybody has a different size monitor? My 1:1 view is going to be different from somebody using a 720p monitor.
I'm being serious with my questions, not condescending.
Hmmmm. I guess I understand what you're saying, but 1:1 looks different on different monitors, doesn't it? So isn't it a kind of poor universal unit of measurement? Like I said, I'm using a 1920x1200 monitor. So 1:1 magnification on my monitor is something like 1456x1120 for an M43 shot. If I were to use a 1650x1080 monitor, wouldn't the 1:1 magnification be a smaller area of the picture?The term "100%" crop is quite unambiguous -- and independent of monitor size or the size (in pixels) of the crop or of the original digital image.
You enlarge the image to 100% (or 1:1 proportion) in Photoshop/Lightroom/whatever and take a crop of the area of interest. It doesn't matter if the cropped image is (for example) 400x300 pixels or 800x600 pixels -- both of these are 100% crops because you did the crop when the magnification was set to show the actual pixels. The 100% refers to the magnification of the image when the crop was made.
The Olympus m4/3 cameras (E-P1/E-P2/E-PL1) deliver a maximum image size of 4032x3024 pixels while the Panasonic m4/3 cameras (G1/GH1/GF1) produce a maximum image size of 4000x3000 pixels.Hmmmm. I guess I understand what you're saying, but 1:1 looks different on different monitors, doesn't it? So isn't it a kind of poor universal unit of measurement? Like I said, I'm using a 1920x1200 monitor. So 1:1 magnification on my monitor is something like 1456x1120 for an M43 shot. If I were to use a 1650x1080 monitor, wouldn't the 1:1 magnification be a smaller area of the picture?
Thanks for your analysis Jonas. I have both the 20 1.7 and PL 45 2.8 and I agree with your assessment of relative sharpness of these two lenses. I like the PL 45 for its primary role as a macro lens, but I'm less enthusiastic about using it for portrait and most landscape work (the exception being landscape detail). The Contax G 45 seems to be readily available at reasonable prices so I may pick one up and see for myself how it compares with the PL 45.Hi,
I don't have both, and will never have. So, I can only give you my two cents based on indirect comparisons.
From my first, and a bit sloppy, resolution test I can say the Planar 45 has as good resolution in the center as the little Panasonic G20/1.7, maybe a tad better. At f/2 the Planar contrast may be half a notch lower, I have to do a better controlled test to see that (I had to push the Planar images half a stop as I forgot to compensate for my quick non standard setup). At f/2.8 and f/4 the Planar is as good or better than the pancake.
The pancake in turn is a notch sharper than the PL 45 2.8.
The Planar seem to hold all the way to the borders.
The Planar bokeh can be a bit busy at f/2 (this is a Zeiss after all, it is all about micro contrast). At f/2 the PL 45 2.8 doesn't do much at all...
At f/2.8 the Planar bokeh is more neutral. Also this is something I have to look closer at during the week. The PL 45 2.8 shows some bright rings and onions when looking closer at OOF highlights, I guess there is some ASPH lens elements somewhere?
But, these are different animals. A new slow macro lens with AF and AE and OIS vs a completely manual medium fast normal lens from the 90's... Now I have sold my FF stuff but for the money involved I would much rather pick up an EF100/2.8 USM MkII than the PL 45 2.8. Whatever that comment has to do with everything.
I hope somebody having both these lenses notice your request.
regards,
/Jonas
