Now I compare it to the 65mm in a more controlled test. This was on a tripod with no IBIS on, self timer, manually focused on the lower 1/4 of the center of the frame, 5.6. When it came to this test, even 2.8 on the 65 was much better than 5.6 on the 55. The ground is about 40 feet away and I cropped to the lower left corner at around 3500px, reduced to 2200px in order to fit the upload...
55V @5.6:
65XCD @5.6:
No matter how I use this lens, this is the story all around with the 55V I have received, so considering my primary use for this camera and lens setup are landscapes and aerial landscapes, this is just flat out not going to work. Either I have a really bunk 55 or it's design is causing this and I will then have to return both the 38V and 55V and just stick to my 45P and 65XCD.
On the plus side, I love the AF, design, size, weight, uniform 72mm filter and shade bayonet size of these new lenses, they pair perfectly with my 28P. But if the optical performance is not there, none of the aforementioned really matters to me.
I have uploaded a full res set and raw files to dropbox to share with Hasselblad and B&H. I'll see what they say and then decide from that point, but as it stands right now, I simply can not get usable images from this lens. I also have a friend locally who has the 55V and is willing to loan it to me to compare so I am going to do that tomorrow.
I hope others get better IQ out of this lens than what I am seeing here...
