Looking for drawings of Leica PC Super Angulon R 28mm f2.8
Hi,there.
I am looking for the drawings of Leica/Schneider PC super angulon 28mm f2.8 lens, only find rough image from internet.
Could anyone have the file or E-Copy for sharing?
Thanks.
Regards
Deane
usm
It was not really good in the edges, even without shifting. I used it a lot with M240 and tested it with the M10r. Using it cropped was ok with the 907x.
A 28mm lens with shift would be cool for the X system...
BGancsos
Thanks! Yes the 28 seems elusive.
rdeloe
Hi,there.
Thanks.
Regards
Deane
I'm not sure what kinds of drawings you need, but here are several: https://www.overgaard.dk/pdf/PC-Super-Angulon-R_28_mm_Technical_Data_en-1.pdf
I expect you know this already, but this lens is made by Schneider-Kreuznach and was also sold under the S-K label with various mounts. The Leica version is identical except for the mount and the cosmetics. Here's the Schneider-Kreuznach manual for the lens, which has some different drawings: https://www.manualslib.com/manual/1...nach-Pc-Super-Angulon-28-Mm-F-2-8.html#manual
I have pictures from a disassembly and re-build project. If there's something in particular you need a picture of on the inside, I might have one.
Thanks, I have the file above, as I need maintenance the lens and hope to have the inside drawings for reference in advance.
