usm
Hi!
Want to share my thoughts about a repro setup based on a Hasselblad 907x with the CFVii50c back. First, I know that there are higher resolution cameras (GFX, H6, PhaseOne) but I have the 907x - so this is the starting point. I also have a ArcaSwiss Factum which gives me 15mm movements. I think that a autofocus is not that important because there is time to do that manually. The main question is; Do I have to use flashes or LED lights? Until now we were using flashes to black out the room light. But for flash I have to use a lens with a shutter. I think that a Broncolor LED F160 with a CRI of 97+ would be a good decision (used with a big soft box like 30x180 (1'x5.9') or 30x120 (1'x3.9').
Regarding the Factum: Do you think it is possible/useful to shift the back to get around a 100mp image. Can I reach the FADGI/ISO/METAMORFOZE levels with a stitched image?
Which lenses are possible:
1. Hasselblad XCD Marco 3.5/120 - costs about 3.900 Euros. Easy to use and possibilities to do focus stacking if there are 3D Objects.
2. Hasselblad HC Macro 4/120 - cost about 4.750 Euros (there are some used but with more than 30000 shots). The package is bigger because of the Adapter and there is NO autofocus and it is NOT possible to use the lens on a HTS Adapter for stitching. I could use the lens with a borrowed H6D to get higher resolution if necessary.
3. Hasselblad V Makro-Planar CFi - costs about 1.200 Euros (if I can find one). No autofocus but useable on the fact with shift. Needs LED light because the 907x can't use the lens shutter.
4. Since I have a Factum, I am thinking of a 100 to 120 mm lens from Rodenstock or Schneider Kreuznach - this is the biggest "black hole" I have.
Which lenses are useful for art reproduction?
Apo-Macro-Sironar digital 120 mm f/5,6
The ALPA Makro Switar 5,6/105 mm is just for Alpa - right?
Schneider Apo-Digitar 4,5/90 mm
Schneider Apo-Digitar 5,6/120 mm
There is also a new FADGI/ISO target:
Does anyone know that https://deltae.picturae.com will update to that target?
Thanks for helping me to decide!
Greetings. Mario
Greetings. Mario
