Don, thank you for your guidance, I really appreciate it!And if you really want critical focus you will want a good bahtinov filter . There are many suppliers- perhaps like this one. The grating is what makes critical star focus possible. https://bahtinovmask.com/products/kase-bright-star-professional-focus-mask-threaded-filter
Thank you and thanks for the link as well, I will take a look at that!BTW that formula is in seconds. A 23mm lens would allow you ~21 seconds of exposure. You may have to adjust the formula for the large sensor on the GFX but its a starting point. A good reference to lens defects during astrophotography is at https://www.lonelyspeck.com/a-pract...rations-and-the-lonely-speck-aberration-test/
I think you're referring to the "500 rule?" Which is 500/focal length (in 35mm equivalents) to determine exposure time in seconds that will give "acceptable" star trails. So, for the equivalent of a 20mm lens this works out to 500/20 = 25s. YMMV, of course, so adjust up or down to taste. Once the shutter speed is set, then adjust ISO to get a reasonable exposure.Greg- if you are not using a tracker, the rough formula for maximum time is 1/focal length. A bit less time if you are enlarging to a great extent.
Most likely the nikon 19mmf4, either adapted or the remounted and rehoused cambo versionGreg
Someone makes a 19mm for the GFX. Can't remember who. Don Libby has one.
Might it be a Laowa lens, which I think does exist in GFX mount? (I have no experience of that one though!)Most likely the nikon 19mmf4, either adapted or the remounted and rehoused cambo version
Thanks Ed, I sent you a direct message. Thanks for all the help and btw great images. I think I may have been making this more complicated than it has to be.I also have one shot with GFX100S plus the Pentax 25mm lens, which I can't yet post here because it's for a specific purpose that requires it to be under wraps. But I can share it with you by direct message if you're interested. Just shoot me a note if so, and I'll share with you
