You make wonderful photos with your kit 'anyone' (wish I could address you by your first nameThis is exactly what I did as well, just Cambo based.
Hi Darr,Received the XV Lens Adapter and XH bracket last week and was able to try it out this afternoon -- total fail!
A lens was not recognized even though I went through the steps of making sure the lens was cocked (just like using a Flexbody), the back was in electronic mode, and I placed the lens adapter on the 907x first, then the lens, and did it three times. After it failed to recognize the 'V' lens, I placed the 45P on the 907x and had no problems taking a couple of quick cat photos, so I am pretty sure the adapter (even though it is a dummy piece with no contacts) is at fault. It's all going back and I will be spending the money on what I initally wanted to get (an ALPA 'V' lens adapter for my TC), but since it costs a lot more, I wanted to try this first.
What I am trying to get together is the lightest weight travel kit with a mix of ALPA and Hasselblad lenses. I decided when I was looking at purchasing a Hasselblad 'V' 40mm lens that I really should just combine my ALPA and Hasselblad gear around the ALPA bodies since I have some very nice ALPA Schneider wides and the adapter I am getting is made from the Flexbody. If anyone is interested in a very nice Flexbody, I'll be putting mine up for sale once the ALPA 'V' Lens Adapter arrives.
Thank you to everyone that contributed to this thread!
Kind regards,
Darr
I'm not sure what mean by "not recognized", darr. The XV Adapter is a dumb mount adapter: Using the 907x, you set the back/body to eshutter mode, fit whatever lens you want to the adapter with the lens shutter cocked, and manually stop down the iris. That's it. Making an exposure means telling the back to make an exposure, it has nothing to do with the lens; you just by pressing the 907x shutter release, the back performs an electronic capture, the lens shutter is inert. It's not like using a Flexbody at all, because the Flexbody uses the the lens shutter. There's no way to trip a V-system lens's shutter on the 907x body with the XV adapter.Received the XV Lens Adapter and XH bracket last week and was able to try it out this afternoon -- total fail!
Kind regards,
Darr
Either that or just change the Camera Type from 500 to Any (Electronic Shutter), which is much more sensible IMHO because it changes behavior of the back all together (with more potential options in the future).Based on my experience with the X1D, I just switch to electronic shutter mode and I'm off to the races with my adapted lenses using the electonic shutter.
FloatingLens:Either that or just change the Camera Type from 500 to Any (Electronic Shutter), which is much more sensible IMHO because it changes behavior of the back all together (with more potential options in the future).
In other words,
The approach with camera body selection that Hasselblad came up with makes full sense to me, you just need to know XV Adapter = Any (Electronic Shutter) due to reasons given above.
- Any (Electronic Shutter or Flash Sync) needs to be chosen if you cannot rely on the full mechanical coupling of the original V system cameras.
- Any (Flash Sync), if the mechanical pin from the 500/200 series bodies is missing and you have lens with built-in shutter and shutter cable available.
Darr, I also love my tiny Alpa TC and have a set of V lenses I like. For me the key piece was a Litz Studio Alpa-to-V leaf shutter adapter (which you can get from Litz’s eBay store). It sounds like that’s the adapter you might be getting already. The maker is a terrific and highly skilled machinist in South Korea. All your V lenses with leaf shutter will work. He even made me a 17 mm shorter adapter so I could use my Alpa tilt spacer, so now I can use any V lens with its leaf shutter on an Alpa body and a Phase One or Hasselblad back. You can even turn an inexpensive Nikon cable release into a one-shot release that wakes up the back and triggers the leaf shutter on the V lenses, as I documented here:What I am trying to get together is the lightest weight travel kit with a mix of ALPA and Hasselblad lenses. I decided when I was looking at purchasing a Hasselblad 'V' 40mm lens that I really should just combine my ALPA and Hasselblad gear around the ALPA bodies since I have some very nice ALPA Schneider wides and the adapter I am getting is made from the Flexbody. If anyone is interested in a very nice Flexbody, I'll be putting mine up for sale once the ALPA 'V' Lens Adapter arrives.
You‘re right, Godfrey! I mixed it up, post above to be ignored (it belongs into an imaginary CFV II 50c threadFloatingLens:
- The XV Adapter tube is designed to work with the 907x or X1D series cameras only. It allows use of V system lenses on the X system bodies.
- You can't change the camera type on the CFVII 50c back when it is connected to the 907x ... the interface is completely electronic and informed by the 907x body stub. You can only switch the shutter operation to "electronic shutter" as I showed in the video. You can change the camera type on the back when the back is fitted to a Hasselblad SLR, Flexbody, or other technical camera configuration.
The options you list above are the options for use of the back only with Hasselblad SLR cameras, or Flexbody, or technical cameras. They are not apropos for the 907x.
Hi Darr,
Hmmmmm. Based on my experience with the X1D, I just switch to electronic shutter mode and I'm off to the races with my adapted lenses using the electonic shutter. Unless the 907 requires you to indicate that there's no lens mounted (as with the Fuji GFX series, from what I understand), it should work similarly - i.e., there's no recognition of the lens per se. I know that Godfrey and others have been using adapted V system lenses on the 907. I'd hold off on returning the adapter and tripod foot until others here have had a chance to help you troubleshoot.
John
I don't think anything failed at all; I think you simply didn't expect what was going to happen correctly. If you want to record an exposure with a V-system lens and its lens shutter onto a CFVII50c back, you fit the back to a Hasselblad 500, 200, or Flexbody, put the lens on the body, connect up the cable (on Flexbody) for shutter synchronization to the back, and go make exposures. That is not what the XV Adapter is for; the XV Adapter lets you use your V-system lenses in full eshutter mode on 907x and X1D bodies.
I made a simple video just now showing how to fit the 907x body to the XV Adapter, set the eshutter mode, fit a V-system lens to the XV Adapter, and then make a couple of exposures.
Tried, but changing camera type is not accessible when using 907x.Either that or just change the Camera Type from 500 to Any (Electronic Shutter), which is much more sensible IMHO because it changes behavior of the back all together (with more potential options in the future).
In other words,
onasj,Darr, I also love my tiny Alpa TC and have a set of V lenses I like. For me the key piece was a Litz Studio Alpa-to-V leaf shutter adapter (which you can get from Litz’s eBay store). It sounds like that’s the adapter you might be getting already. The maker is a terrific and highly skilled machinist in South Korea. All your V lenses with leaf shutter will work. He even made me a 17 mm shorter adapter so I could use my Alpa tilt spacer, so now I can use any V lens with its leaf shutter on an Alpa body and a Phase One or Hasselblad back. You can even turn an inexpensive Nikon cable release into a one-shot release that wakes up the back and triggers the leaf shutter on the V lenses, as I documented here:
DIY *one shot* wake-up + shutter release cable (e.g., Phase One IQ4 to Hasselblad V lens with leaf shutter)
DIY *true one shot* wake-up + shutter release cable (e.g., Phase One IQ4 to Hasselblad V lens with leaf shutter) Ever since I started using medium format digital backs, I've wanted to be able to frame and focus an image in live view, then *while in live view* press a single shutter release...www.getdpi.com
Godfrey,
Sorry for the late reply, but out of town and off the grid!
I never expected the setup to work like the Flexbody, as the Flexbody is a tech camera with completely different setup requirements. I said "... I went through the steps of making sure the lens was cocked (just like using a Flexbody)," the lens was cocked in the correct position like it must also be when putting a V lens on a Flexbody.
I used the steps outlined in the 907x manual (pages 150 & 111), but the digital back did not recognize the lens. I went through the steps three times, and I did not try a different lens because there is nothing wrong with the lens mount of the lens I tried. Should I have tried another lens? No! If the adapter is that finicky, it is not worth my time when another option is available. I remember you posted your XV adapter had to go in for repair because of a lens/extender mount issue in the "Fun with 907x" thread, and I have also read other photographers having problems. These adapters are known for faults, and IMO the build quality could be improved. After packing it up to ship back, a soft rattle could be heard from the package. I have no idea what it was, but I am glad it went back as I have a better solution for my needs on order.
Thank you for your suggestions and for posting the video as it may help someone that chooses not to read the manual.
Best to you,
Darr
I have attached pages #150 and #111 of the 907X-50C-User-Guide_en I am currently using.Hi Darr,
Hmm. My 907x manual only has 112 pages in it, and my CFVII 50c manual only has 118 pages in it. And I don't see any instruction on using the XV Adapter at all, just an accessory listing for it... ????
I understand. Maybe I just got it wrong. I have no problems using an adapter with my Fuji cameras and an old Nikon AI-S lens. Maybe my particular 907x has a software glitch. I do not know, but it is behind me now. I appreciate your persistence, but let's just leave it here, okay?As I asked earlier, what do you mean by "recognize the lens"? The XV Adapter is a dumb tube with no electronics in it ... How could the body actually recognize anything put on it? There's *no* connection to the 907x other than the mechanical lens mounting flanges; the back does not recognize the lens. You just set the back to "eshutter" mode and it turns on live view when you half press the shutter release. You fit a lens and it just sits there ... you set a focus, stop down the aperture, and set the aperture. You make all the ISO and exposure time settings on the back, manually. What lens is on the tube is irrelevant, the body and back do not care.. The tube is not finicky at all: it just does nothing but hold the lens and body at the correct distance, in optical alignment. That's it.
I have been using tech cameras since the start of my commercial career in the early '80s. When I began my digital transition it was with a Nikon D200. Shortly after that, I bought my first MFD tech camera, an Arca Swiss ML2, but I eventually made the switch to ALPA. I decided ALPA was a better solution for my needs for a few reasons, one being the ability to utilize the Hasselblad gear I already owned (magazines and viewfinders). You will not meet a photographer that enjoys Hasselblad equipment more than me (okay maybe YOU with their Space memorabiliaI know you have another solution to use your lenses on the Alpa now with the CFVII50C back, but that's a completely different thing to using the XV Adapter tube on the 907x body with the CFVII50C back. I've never even seen an Alpa (other than in pictures) so I have no idea how that and the adapter you bought works.
All good!...
I have only tested the 907x with a 45P lens in my backyard (been very busy lately). It was the first time I have ever used autofocus on a MF camera. The files look sharp enough for me to see if it can be my walk around MF camera. I hope so because my needs for shooting MFD are more with tech cameras as I shoot mostly in the studio (for work) than I ever do outside, but I am trying to do more MFD camera work outside these days. Even though I am sure the XCD 21 lens would be nice to own, I am sticking with my ALPA wides (SK 28/5.6 and SK 35/5.6) until further notice. I had no plans on upgrading as you may already know, but I am not disappointed either. ...
Hasselblad calls now 907X and CFV II 50C their V-System, while XCD lenses and X1D cameras are called the X-System. The 5xx cameras and V-mount lenses are apparently the classic V-system. Confusing, IMO.Hi Darr,
Just checked ... discrepancy in page numbers and numbers of pages are because I have the 907x/CFVII 50c Special Edition docs on my iPad Pro (was on travel when I wrote that) and they're slightly different from the standard edition 907x/CFVII 50c docs..
After looking at the quoted sections of the pages, well, there's nothing implied there that the back or 907x is going to "recognize" a V-system lens. It says specifically in the accessory section that "Lens corrections for V System lenses are available with Phocus version 3.4 or later. Note that they have to be manually selected" (in Phocus). There's nothing wrong with your 907x/CFVII 50c, or the adapter you had... But 'nuff said on that.
All good!
I still hardly use AF at all. I'd rather use focus magnification and focus manually...
I'd never heard of the term "technical camera" until sometime after the world of digital cameras came about. I and my friends always referred to such things as 'studio cameras' or 'view cameras'. Perhaps my photographic community just wasn't in the right niche.. I wonder when the term actually came about. It's a point of minor curiosity.. I am curious about maybe acquiring a Flexbody to work with, at some point.
But for the present, and since my 907x SE just returned from being analyzed and passed for "fine", it's time to just get back to some shooting and using it. And I think it's rolling up on when Dave Odess should be shipping my A16 back to me as well... I'm likely going to shave down my kit somewhat over the next year to concentrate more fully on the Hasselblad X and V gear as I seem to get my best photos with it nowadays, whether because of the gear itself or because I just enjoy using it more.
Onwards!
"View Cam" was the term for a large format camera in general. It had subdivisions of "field cam", which were typically wooden cameras with less movements and lighter along with "tech cam" or "monorail" which was the studio cameras with full movements.I'd never heard of the term "technical camera" until sometime after the world of digital cameras came about. I and my friends always referred to such things as 'studio cameras' or 'view cameras'. Perhaps my photographic community just wasn't in the right niche.. I wonder when the term actually came about. It's a point of minor curiosity.. I am curious about maybe acquiring a Flexbody to work with, at some point.
There's no rhyme or reason anymore to the systems, especially considering the X-system was a 35mm pano (XPan). Originally, the systems were named by the lens mount.Hasselblad calls now 907X and CFV II 50C their V-System, while XCD lenses and X1D cameras are called the X-System. The 5xx cameras and V-mount lenses are apparently the classic V-system. Confusing, IMO.
