City scapes are much better during winter times as an example above by Bart, had it been shot during summertime , the building on far right would have been covered by the tree leaves.Blooker & BreitnerTower - Amstel plein, Amsterdam NL ...
| gfx-100ii | laowa 20mm f/4 zero-d shift |
For the Breitner tower I used maximum shift, but still it wasn't enough. So the last corrections were done in post.Bart,
Did you use any shift for these shots with the Laowa 20 or just correct in post?
I agree with what you say here, particularly with regards to correcting to exact verticals. However, that depends on the relation between the height of the subject and the distance from the subject. That is very obvious in this particular photo where the main subject could probably do with somewhat less correction, while the building on the left, which is not nearly as tall, could do with some more. In addition, since only part of the building on the left is shown, it will never give the impression of being "top heavy" and nearly falling over, which is sometimes the case when the whole building is visible.For the Breitner tower I used maximum shift, but still it wasn't enough. So the last corrections were done in post.
It's good practice IMO while adjusting shift to keep some perspective distortion and then finish to taste in post.
In particular when shooting hand held it can be difficult sometimes to prevent overcorrecting or keeping the camera level.
And never correct to 'exact' verticals as this could look very odd and unnatural.
Especially for high-rise always keep a certain amount of perspective 'distortion'.
Kind regard.
