NONS Camera: Instax SQ for Hasselblad V system...
Godfrey
NONS Camera : an Instax SQ back for Hasselblad V system
Hasselblad V system 6x6 exposures are 56x56 mm in size, and of course the Hasselblad has interchangeable film magazines. So ... In the now distant past (about 6-8 years ago), a kickstarter came up that married a Fuji Instax SQ processing mechanism with a replacement back (for Leica M, Nikon, and various other 35mm cameras) containing enlarging optics and a mirror to exploit making instant prints with your favorite 35mm film camera.
Of course, I bought in on one. I got the Leica M model and it works well enough: replace the back, use a 35 to 135 mm lens on it, stop down two stops from wide open for best results, and adjust exposure by +2 stops for losses in the enlargement optical system. Turns out pretty nice instant prints.
But... It's a large device and awkward to carry, somewhat fragile due to all the pieces to put together and keep in alignment, and not particularly conducive to wanting to take for a walk. But it does work.
Thinking about it way back when, I said to myself: 'Well, Hasseblad made a back for instant film, but it only put a little image on a big print, the film is out of production (peel apart type Polaroid or Fuji) and very expensive when you can still find some. The Instax SQ format is 62x62 mm so a 56x56 mm Hassy image would fit it pretty tightly, and you wouldn't need a mirror or optics—it would be much more efficient. ...' And so I started mucking around with various ways of putting one of the Instax SQ processing units onto the back of the Hasselblad 500CM. I finally gave up, saying to myself that I could not fit the Instax SQ close enough to the film plane due to the shape of the processing unit and the film cartridge, and maybe I could just make a box to mount a Mamiya 23 type lens/shutter/focusing mount onto the front of the processing unit instead.
So I acquired a lens and a broken body (to get the lens mount) and started hacking it to pieces so I could build a box behind it. And got stuck because I just don't have the expensive tools or skills required to do a precision job and make it work.
Roll forward to about two weeks ago, and I stumble across a YouTube vid talking about the NONS Camera Instax SQ film back for Hasselblad V. "What? It just snaps on like a normal back? and pushes the film out the side rather than up or down? and ... and ... and ..." Needless to say, I couldn't resist. It arrived yesterday, late, and I had to try it.
1978 Hasselblad 500CM fitted with NONS Camera Instax SQ back and Planar 80mm f/2.8 T* lens
I opened the box, fitted it to the 500CM, put in a pack of B&W film, and did some quick testing.
GDG and Bookcase on Instax SQ
80mm lens, f/8, scale focused, manually timed about 4-5 seconds exposure.
Kitchen Counter with Knives
120mm macro lens, f/11 at 1/2 second
Fat Bike, FLEETWOOD Tire
120mm macro lens, f/8 at about 26 seconds
Counter Outlet with Switches
120mm Macro lens, f/16 at 1/4 second​
I'm pleased with these test shots. I shot the whole pack, but reciprocity failure cost me the other six exposures (underexposure). Instax film isn't really geared to long exposures...
The back is reasonably sized, not overly heavy, and easy to use. It has an on/off switch and a button to eject the print. You can make as many exposures as you want on a frame before ejecting. The dark slide means you can swap other backs on and off partway through a pack of film, and the battery is built-in rechargeable with a USB-C standard port. It has a battery indicator and a frame indicator on the top deck, and a holder for the dark slide.
More info: https://nonscamera.com/products/nons-instant-back
Now to take it out for a walk... :D
Godfrey
A bit of time with the Distagon 50 and Planar 80 shooting onto Instax SQ color film ... seven exposures in better light, all exposed perfectly! I'm very jazzed that NONS Camera built almost exactly what I'd fantasized about. Now I can shoot 6x6, 6x4.5, 33x44 digital, and Instax SQ formats with my 500CM ... All different ways of seeing and recording photographs. Fantastic!
anyone
This is awesome. I still have lots of peel apart film, but this is a nice alternative. How about double exposures and the like? Can you do that?
Godfrey
You can make as many exposures as you want before you press the print process/eject button. Operation of the back is completely independent of the camera's film transport system, except that you should not manipulate the dark slide unless the camera is wound.
I exposed a pack of color InstaxSQ with it ... does a lovely job! :D
anyone
I wonder about the differences of this Instax back to the Hassy PB MkII which seems to do the same..
Godfrey
What is the "Hassy PB MkII"? I've never heard of that. I have seen one or two other implementations of an Instax back for Hasselblad V, one for Instax Mini, but they required using spacers under the focusing screen or other workarounds to accommodate not having the film plane in the right place. The nice thing about this one is that no such workarounds are needed ... I can swap the CFVII 50c with this and just keep on shooting normally.
Godfrey
Ah, I did see that one. It ejects to the top, which orients the image the "right way" on the print (reagent pod on the bottom), but means that a focusing screen spacer is required to achieve the correct focus and film plane alignment.
The NONS Camera back ejects to the side, which allows the back to operate with no spacer for the focusing system. And it sells for $125 or so less than the HassyPB. The only downside is that the print orientation puts the reagent pod on the right in the finished print. Example: some experimenting with shooting my orchid using B&W InstaxSQ...
Cropped to the square, of course, it doesn't matter at all:
Orchid with InstaxSQ BW - Santa Clara 2024
Hasselblad 500CM + Makro-Planar 120mm
Fuji InstaxSQ B&W print
ISO 800 @ f/11 @ 1 second
Auxiliary lighting with a flashlight
enjoy, G
... Oh yes: Please forgive the extremely crude digitization capture with iPhone and desk lamp... LOL! ...
Godfrey
Some more HasselStaxSQ photographs. ;)
Vine Art - Santa Clara 2024
CF Makro-Planar 120mm f/4 T*
Snow Man - Santa Clara 2024
Bronze Horse at Triton Art Museum - Santa Clara 2024
Coffee & Pastry - Santa Clara 2024
Distagon 50mm f/4 T*
Garage Art - Santa Clara 2024
all:
Hasseblad 500CM + NONS Camera InstaxSQ back
Instax SQ Color film.
Larger versions available to view on Flickr.com
enjoy! G
peterm1
Hmmm interesting. Any idea if this would work with the 907x camera or a tech cam with an adapter for the Hassy V system backs?
Godfrey
It can't work with the 907x body because that body is just a stub that transfers all the control from the back (which contains everything) through to a XCD lens, and back. Without the CFV back, a 907x is inert, has no power, and cannot even trigger the lens. It can work with any Hasselblad V system body or back adapter, presuming that the lens and such are all controlled by the camera, not the back.
darr
I wrote a review of the NONs back a while ago, and it was posted on the NONS site; here is a link to where it is on my site:
It cannot work with back adapters because of the design of its body.
At the end of my article, you can see that I tried it with a Sinar 4x5 and Alpa back adapters.
Godfrey
Thanks Darr! I don't have any such back adapters, and was speaking just theoretically ... But I can visualize the problem easily now that I'm thinking of a typical back adapter and the shape of the NONS SQ back.
Fitted to my Hasselblad 500CM, it's a kick to use, really enjoy it. To get around the ISO 800 problem, I picked up a couple of ND and polarizer filters to use with color and have Green and Yellow-Green filters to use with B&W ... Stack a yellow-green with a polarizer with B&W for an even lower ISO and more aperture flexibility. They drop the ISO into a more useful range for a 1/500 sec fastest exposure shutter (and the yellow-green filter on B&W nets a particularly nice tonal curve for my way of seeing the world). :)
Sheesh! Just looked in my instant film box ... I have to restock on Instax SQ B&W film again! LOL!
abruzzi
I do basically the same thing with my Lomo Graflok—ND or other filter since most of my shooting is in bright New Mexico sun, and since very few mechanical leaf shutters can actually get up to 1/500 of a second, NDs become necessary.
Godfrey
I hadn't used the NONS back (or the 500CM) for a bit, but was inspired a few days back... I loaded up a pack of Instax SQ color and shot it around the house to re-learn proper exposure technique. It really does produce lovely results! :D
bensonga
Godfrey and Darr....as always, you have been a wealth of information and most importantly...INSPIRATION! I have wanted to try instant film/prints on my various medium and large format cameras for many years.
I ordered/purchased a NONS Instax back for my Hasselblad cameras, color and monochrome Instax SQ film and it all arrived here a few days ago.
I expect this will require a very different approach/adjustment of expectations for the "printed image" vs what I usually expect when making prints from my film/digital images.
