3 years after my last Phase One Lenses test I decided to do new one with more lenses this time including 6 Schneider Kreuznach Leaf Shutter Lenses and put result of Nikkor 105mm f1.4 at D850 as comparison to see where full frame is standing against medium format.
Comments are welcome
Sorting by sharpness, sorting by bokeh,full-size photos and result in tables can be seen in my blog post:Phase One Lens Test (click below images for full size photos)
Here it is result of lenses rating sorted by center Sharpness.
Mamiya 80mm f4.0 MF - Sharpness: 10 Bokeh: 6 (C Version)
Schneider Kreuznach 80mm AF LS f/2.8 - Sharpness: 10 Bokeh: 7 (2 copies tested) - MTF for Schneider Kreuznach 80mm f/2.8 LS Schneider Kreuznach 80mm f2.8 LS Specifications
Mamiya 80mm AF f2.8 - Sharpness: 10 Bokeh: 7
Mamiya 24mm f4.0 MF Fisheye - Sharpness: 10 Bokeh: 2 (C Version)
Schneider Kreuznach 75-150mm AF-D LS f/4-5.6 - Sharpness: 9 Bokeh: 7
Phase One 150mm f2.8 AF-D - Sharpness: 9 Bokeh: 9
Phase One 120mm f4.0 Macro D /Manual Focus/ - Sharpness: 9 Bokeh: 7 (D Version) - MTF for Phase One / Mamiya 120mm Macro Phase One 120mm f/4 D Macro MF Specifications
Schneider Kreuznach 40-80mm AF LS f/4.5-5.6 - Sharpness: 8 Bokeh: 6
Schneider Kreuznach 55mm AF LS f/2.8 - Sharpness: 8 Bokeh: 6
Mamiya 150mm AF f3.5 - Sharpness: 8 Bokeh: 8 (2 copies tested)
Mamiya 55mm AF f2.8 - Sharpness: 8 Bokeh: 6 (non D version)
Phase One 45mm f2.8 AF-D - Sharpness: 5 Bokeh: 5
Mamiya 105-210mm AF f4.5 - Sharpness: 9 Bokeh: 6 (non D version)
Schneider Kreuznach 110mm AF LS f/2.8 - Sharpness: 8 Bokeh: 8
Mamiya 210mm AF f4 - Sharpness: 9 Bokeh: 9
Mamiya 45mm AF f2.8 - Sharpness: 8 Bokeh: 5 (non D version)
Mamiya 35mm AF-D f3.5 - Sharpness: 7 Bokeh: 5
Mamiya 35mm MF f3.5 - Sharpness: 7 Bokeh: 5
Schneider Kreuznach 28mm AF LS f/4.5-5.6 - Sharpness: 7 Bokeh: 2
Mamiya 55-110mm AF f4.5 - Sharpness: 7 Bokeh: 7 (non D version)
Mamiya 110mm MF f2.8 - Sharpness: 6 Bokeh: 8
Mamiya 55mm MF f2.8 - Sharpness: 6 Bokeh: 6
Hartblei Tilt Shift 45mm MF f3.5 - Sharpness: 6 Bokeh: 5
Zeiss 110mm f2.0 /Hasselblad V/ - Sharpness: 6 Bokeh: 9 (F Version) - MFT for Zeiss 110/2.0 Zeiss 110mm f2.0 Specifications
Mamiya 80mm MF f1.9 - Sharpness: 6 Bokeh: 7 (N Version)
Mamiya 150mm MF f2.8 - Sharpness: 7 Bokeh: 9
Mamiya 150mm MF f3.5 - Sharpness: 6 Bokeh: 9 (2 copies tested)
Mamiya 200mm APO MF f2.8- Sharpness: 5 Bokeh: 9 (tested with extension tube and showing a bit weaker result at minimum distance)
Mamiya 300mm APO MF f2.8 - Sharpness: 4 Bokeh: 9 (tested with extension tubes and showing a bit weaker result at minimum distance)
Russian Projector Lens 35KP 140mm MF f1.8 - Sharpness: 2 Bokeh: 10
Russian Arsat 30mm f3.5 Fisheye - Sharpness: 1 Bokeh: 1
Camera: Phase One DF
Digital Back: Leaf Aptus 75
Tripod: Manfrotto 055XPROB
Tripod Head: Manfrotto 486 MG
Self Timer: 10 sec
Distance: 2 meter /200mm f2.8 APO and 300mm f2.8 APO lens were shot with extension tube due to minimum focus distance bigger than 2m /
Settings: ISO50, Aperture Mode
Focus Mode: Manual focus lenses were focused with focus confirmation on camera. Every shot was checked on 100% on camera and refocus after this. Best of 4 shots was chosen for each lens. /I didn't use autofocus since it is quite inaccurate in low light condition with busy backgrounds/
Test Target: Distance to from camera was 2.0 meters and target have Arial fonts with sizes from 1 to 30
All lenses were tested with 4 shoots, and from following lenses I have 2 copies each:
- Schneider Kreuznach 80mm LS f/2.8 ; Mamiya 80mm AF f2.8 ; Mamiya 150mm AF f3.5
All copies have given same result.
Teo
Teo Totev London Fashion Photographer
Self Timer: 10 sec
Teo
