diggles
When I was putting the above setup together I wasn't sure which length to order so I ended up getting this set on eBay:
I've since used these and RAF extension tubes and am happy with both.
If you choose to try the Hasselblad V adapter route, another benefit is that the opening is larger than 65mm which will allow you to use more of the 180T's image circle. You will also be able to use a shorter tube because the V adapters add length.
