I had a member ask about the image circle on the Rodenstock HR Digaron - S 180 image circle, so I am posting this here in case it might benefit someone else. This is with 20mm shift (left, right, top, bottom).
IQ4 150which DB did you test with? IQ4 150 or 33x44 format?
That looks ridiculously good.The transfer function, as published by Rodenstock for the 180mm Diagron-S, certainly looks rather straight and high to me.
Are you sure about the coverage? Schneider's technical data sheet says image circle of the APO-Digitar 180mm f/5.6 is 120mm. To cover 4x5 it would need to be 157mm. The Componon-S 180/5.6, which I think was the starting point for the Digitar version, easily covers 4x5 with its 205.9mm image circle.SK 180T is better than digaron-s 180mm at the edge of image circle. SK180T also cover 4X5 film.
Dave, I am not sure I understand the question, but let see if this helps. This is the horizontal shift only (middle row), I have added a vertical grid to see if that helps with your question.Hi Greg,
Thank you very much for posting this. It looks like the image circle ends somewhere around 100 mm. The corner of the horizontal-only shifts begins to get the fringe effects. That’s ~ 102 mm. Is that your impression directly looking at the images?
Dave
The 138mm could also combine the 90mm in the sense that stitching within the 138's large image circle could be a substitute for the 90mm.The latest Rodenstock 138 might actually be a 138 and 180mm lens combined in the sense that it outresolves an old 180 design enough so that you can shoot the same distant elements and then uprezz the image and still have more detail. That would make the 138 the end-all tele.
