A bit more about the lens for those who are curious about these things. But first a confession: they had two and I bought them both. It's always nice to have a backup.
The shop I bought the lenses from had a lot of other lenses for the Plaubel system. The sticker on mine says it came from Studio Gieske, which is a going concern. If you know these folks, say "hi" for me and tell them their 35mm APO-Digitar lenses are going to have a good second life.
I like buying lenses from working professionals because they're unlikely to keep using a bad lens for paid work. If they're in good condition, which these ones are, that means they earned someone lots of money. The photographers at Studio Gieske took good care of their equipment because the cells in both units are in excellent condition.
This is what one of these looks like, front and back. As I mentioned at the start of the thread, this unit is the product of a partnership among Schneider-Kreuznach, Plaubel and Jenoptik. That's a Schneider-Kreuznach electronic shutter, in a custom arrangement that is screwed to the Plaubel lens board.
The rear lens group twists off easily. The front lens group is a different story. It's in that cavity so deep that it's difficult to remove the lens cap. I couldn't get a hand grip on the lens group to get it off, and had to build a special tool out of some aluminum pipe. There's rubber on the inside of this tube to protect the front of the lens. Tightening the nut provided a good clamping grip. With a quick twist, the front lens group comes loose.
The front and rear lens groups are very tiny. There's a picture earlier in the thread that shows how the rear lens assembly sits loosely inside the housing with the Copal 0 threads, and is held on only by the pressure of the ring around the rear.
On both of the lenses I bought, three Copal 0 shims totalling 0.21mm were included. I only needed one of the 0.09mm shims to get excellent results on my GFX camera. As explained earlier in the thread, the thickness of the cover glass and the close distance of the exit pupil to the sensor appear to be the reason a closer spacing of the lens groups is needed than normal.
The picture on the right shows the solution the three partners devised for the fact that the front lens group is in the cavity so deeply that mounting filters on the front lens group is nearly impossible. There's a set of threads in the board for filters. This is why in the Schneider-Kreuznach Digitar brochure you see a special IIg centre filter with M67 x 0.5 threads; it's for this assembly.
Unless something new turns up, I think this completes the story of the Schneider-Kreuznach APO-Digitar 35mm f/5.6 L-88. On my F-Universalis setup, where I can only shift 8mm anyway, the 70mm image circle it provides is a perfect match. I am looking forward to working it hard during fieldwork that hopefully starts soon (as long as winter gets over itself and makes way for spring!)
