Fun with Medium Format FILM Images!
Makiflex Retro 320 - 2 by Nokton48, on Flickr
9x12cm Foma Retro 320 cut film, exposed at EI 125. Plaubel Makiflex Standard camera body, Kern-Arau 360mm F11 Repro Process lens, exposure 1/15 sec at F22, Developed in straight Microdol-X developer, 30 minutes development at 18C, in a JOBO Multitank 5. Scanned on Epson 4490 scanner. The negative is cropped somewhat (about 6.5cmx9cm) for easy scanning. Observations: Even at 30 minutes development, the negatives are quite low contrast. Also, there is a dark blue antihalation dye on the back of the film, which turned my Microdol-X BLUE! And it even turned my Kodak Rapid Fixer BLUE! After thirty minutes washing, all traces of the dye was completely rinsed away. I LIKE THIS FILM! I am so glad I have it. Of course, I am NOT following the FOMA instructions, just going by my own intuition. Since this film is not available in 120 size, this is a good alternative for me.
I took these photos in 1996 but it wasn't until today that I put them together. I liked the way it looked.
Hasselblad 553ELX, 60mm CF.
I like it Vince, especially knowing the history of that camera. As a matter of my education, how did you colorize the image? Thanks for posting. I just got my Nikon Coolscan 8000 scanner up and running and will from time to time scan some of my old negs.
Dave
Thanks Vince. I bought two specialized programs to color old B&W images......But one is "AI" and it is supposed to "guess" at the colors and apply them. The second program you have to roughly "paint" each section of the image and the program is supposed to find boarders. The first does not do a great job most times, and the second demands more patience than I now have. Thanks for the info.
Dave
I love it when you're able to stop by and make my day with your spirit and your images. Thank you!
Ray, you are so kind!
Thank you. I will stop by more often.
I am spending more time with film than digital and will share more as soon as I hit the darkroom.
Best to you,
Darr
A trio of Plaubel Makiflexes by Nokton48, on Flickr
The final Swan Song of the Plaubel Camera Company, (in the early 1960's) was the reflex-SLR version Plaubel Makiflex. Here is my collection of Makiflexes, the two on the left, are the Automatic "Makiflex". Very similar to a European Auto Graflex, with automatic diaphragm mechanism. You cock the lens, and it stops down the lens right before exposure (hence "Automatic"). The Plaubel original lenses are the 180mm Schneider Xenar, and the 210mm F4.5 Schneider Xenar. On the right, is the "Makiflex Standard" with 150mm F2.8 Schneider Xenotar. This model has a more restricted range of shutter speeds, and no auto-iris provision. These cameras are from what I call "The Golden Age of Photography".
I love retro camera porn!
Kingswood Gardens Hassy 30mm Distagon Fisheye 1 by Nokton48, on Flickr
Frog Pond, Kingswood Gardens, Mansfield Ohio. Kodak 70mm Surveillance Film, ADOX Borax MQ dev, Hasselblad 500C/M 30mm T* Distagon, Handheld exposure. Arista #2 8x10 Matte RC paper, Multigrade dev. Processed in 70mm Kindermann Dev Tank. Kodak Surveillance reminds me a lot of the older Tri-X emulsion. The sun was just out of the frame upper left corner. The circular garden works well with the Hassy Fishy lens.
This was a fun shoot! :)
Petzval type unmarked brass projection lens Makiflex No iris by Nokton48, on Flickr
Unmarked Petzval type beautiful brass Projection Lens vintage late 1800's? Central stop removed, very swirly beautiful bokeh. I'd guess 200mm focal length, I wanted speed and I'd guess about F3.5 wide open. Sharpest in the center, central bouquets were focused on and are sharp! Depth of Field is near nil. Orwo NP22 9x12cm I bought in bulk from Bulgaria. Voigtlander Makiflex Plate Holder pretty good match. RADA made plates from Plaubel and were hooked up with them for a good while. These tend to light leak and I'd retrapped a lot of plate holders, could maybe be improved? I also have some French and Russian Plate holders that seem to work as well. Yes it is sharp in the center only, that was my intention. Removing the central interior stop increased the swirly bokeh, and increased speed to about F3.5 or so. The central stop was blackened by a candle, the black soot got all over my fingers. NP22 developed in straight Legacy Mic-X Replenished. A Deep Tank Developer that lasts for many many years
