In principle, I might be a candidate ... I have some experience with TS lenses and since last year with an Arca-Swiss F-Line. The biggest advantage for me would be the non-existent FFD of a CFV digital back for wide-angle in architecture (I'm an architect myself and also shoot for other offices) With DSLM / DSLR, of course, a certain willingness to compromise is always required, as we have already discussed in detail here in the 35mm lens thread, for example.
Not so much the resolution, but BSI is of course an argument against a CFV 50. However, if I follow the posts here, the solution is not yet clear to me, as the bigger investment will be the lenses. And all in all, I don't know if that would be a big enough step up from my current DSLM setup to justify it. Some of the descriptions about the shutter, flash, long exposures etc. also make me feel unsure about taking such a huge step ... This requires further research.
The CFV 100 C on a technical camera will be a very capable tool for architectural photography. Since your primary use is for architecture, lenses are the key.
With Schneider APO Digitar lenses anything shorter than 60mm will require an LCC. For the times you do need a wider angle lens like the 43XL or 35XL then you will need to take a LCC reference image to compensate for color cast. Not a big deal really because Phocus has LCC functionality, it is called Scene Calibration. So this is easily fixable.
The difficulty with Schneider APO Digitar lenses is that they can be very difficult to find.
With many of the latest Rodenstock lenses you will have to deal with distortion. When shooting at an angle it is not objectionable to me, but if you like to make 1 point perspective images then it may bother you. The issue will be fixing the distortion. I am not 100% sure, but I do not think Phocus has lens distortion correction with camera movement settings built into their software like Capture One does.
The problem here is that Capture One does not accept Hasselblad files so you may have to fix distortion issues manually using Photoshop.
A solution could be to start with the easier to find Schneider lenses like the 35XL, 47XL, 72L, 90n, and 120n. All of these are 'reasonably' priced, sharp, and should do well with the new Hasselblad back. Then you can be on the lookout for the more sought after Schneider lenses like the 43XL, 60XL, and 120ASPH to 'upgrade' when the opportunity comes around.
Hope that helps.
